ducatipaso.org • View topic - Euro turn signal conversion
It is currently Wed Mar 04, 2026 10:05 am
 Post subject: Euro turn signal conversion
PostPosted: Sun Apr 03, 2005 12:43 pm
PostPosted: Sun Apr 03, 2005 11:29 pm
heh ... 1st good luck: Ebay is probably the best source for one. There aren't many around and when they go, they go for a mint. I lucked out and found just the lens, but still spent $75USD on it. I haven't seen the whole kit got for less than $200USD on ebay.
If you can hook up a lens, it's pretty easy to make the conversion with a pair of aftermarket flush-mounts (which is what I did). Somewhere I write it up, recently ... lemme find it and I'll post the link ...
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Tue May 10, 2005 10:54 pm
PostPosted: Wed May 11, 2005 1:34 pm
1997 Monster 750
PostPosted: Wed May 11, 2005 4:28 pm
PostPosted: Thu May 12, 2005 1:47 pm
1997 Monster 750
PostPosted: Thu May 12, 2005 4:12 pm
PostPosted: Thu May 12, 2005 4:16 pm
another alternative to a full-on euro turn signal conversion could be to put some form of universal bulb socket into the sides of the rear housing and have red blinkers. just a thought.
PostPosted: Thu May 19, 2005 8:38 am
Hey
A UK dealer call Mdina italia has euro tail assemblies new for 132 pounds, if you happen to still be interested. They ship worldwide
Arhooly
PostPosted: Fri May 20, 2005 12:28 pm
PostPosted: Fri May 20, 2005 1:12 pm
Yeah, I wound up with just a Euro lens and not the whole assembly, but the 'surgery' involved to get it hooked up very minimalistic. A couple holes in the black plastic pieces inside the lens to mount aftermarket flush mount signals to, and a slightly enlargened hole on either side on the back of the unit to pass the wires though. I used the same style connectors so I could easily switch back to stock - and even leave the aftermarkets in there.
1997 Monster 750
 Post subject: Euro Tail Lamp Conversion
PostPosted: Wed Aug 09, 2006 4:44 am
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
'78 Laverda 3CL Jarama
'84 Laverda RGS 1000
PostPosted: Wed Aug 09, 2006 1:24 pm
Hmmmm.....rather strange. From what I am reading and understand, the '87 Paso 750 that I picked up the other weekend came originally with the Euro light on it, but with a solid red lens, according to the previous owner. He said that with the red lens, you couldn't see the turn signals very well, so he installed some small, aftermarket signals with short stalks on the mud guard. I currently have the taillight lens off of the bike, and there is definitely a light socket on each side of the assembly for turn signals, and the lens has two inserts to separate the turn signals from the taillight/brake light. I didn't pay any attention to whether they looked original or were a modification, but I was actually thinking of hooking them back up, either with or without the aftermarket signals.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Aug 09, 2006 3:20 pm
here u r:
750 Paso
| '92 907 I.E. | '88 750 Paso under construction |
PostPosted: Thu Aug 10, 2006 1:15 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
