ducatipaso.org • View topic - K&N for a 907IE 92???
It is currently Tue Sep 30, 2025 10:40 pm
 Post subject: K&N for a 907IE 92???
PostPosted: Wed Aug 16, 2006 3:44 pm
PostPosted: Wed Aug 16, 2006 4:23 pm
PostPosted: Wed Aug 16, 2006 5:09 pm
-Craig
PostPosted: Thu Aug 17, 2006 8:39 am
Francesco is right.
The DU-0900 is the usually used K&N filter
http://www.knfilterchargers.com/search/ ... od=DU-0900
the high one is this one (which needs airbox modification due to its double height):
http://www.knfilters.com/search/product ... od=33-2003
The DU-0900 should work without any engine readjustments. The high one though, sold as racing filter needs them. This is commented also in some catalogs.
 Post subject: K&N for 907IE
PostPosted: Thu Aug 17, 2006 1:03 pm
PostPosted: Thu Aug 17, 2006 5:51 pm
PostPosted: Sat Aug 19, 2006 12:37 pm
PostPosted: Sat Mar 03, 2007 9:54 am
7 years without any problems.... Very good filter! I wash and reoil it every winter with K & N stuffs. Btw, there are 2 different types, what fit to Paso, one thicker with bigger area for flow ("racing modell") and normal thinner modell. I have both. Air intake noise is little higher, than with normal paper filter and surely airflow to intake is also better... :cool:
