ducatipaso.org • View topic - Compression Readings
It is currently Wed May 06, 2026 4:00 pm
 Post subject: Compression Readings
PostPosted: Wed Sep 20, 2006 11:23 am
PostPosted: Wed Sep 20, 2006 7:34 pm
When You have checked Your valve clearances???? If they are totally wrong, it can happen that way..... I havent measured compressions in my 907, but its easy job in all car maintaining companies and if they are "low", or another is low, U have problems in valves.... I know, that if valve clearences are NOT correct, then U HAVE such starting problems and normally, when engine gets hot, it goes more worst....
PostPosted: Thu Sep 21, 2006 9:49 am
PostPosted: Thu Sep 21, 2006 7:22 pm
PostPosted: Thu Sep 21, 2006 11:58 pm
PostPosted: Fri Sep 22, 2006 12:30 am
Timbo,
Before tearing it down you can do a simple leak down test to determine exactly where the compressed air is going. Have you done this before? It not much harder than a comression test.
If the valves haven't beed adjusted for years/miles this could be the simple cause of low compression. Easier to check valve clearance than tear the top end off. Check out the Ducati Suite for instructions.
PostPosted: Fri Sep 22, 2006 7:46 pm
It can be burned exhaust valves, totally wrong valve clearances, bad valve seats, bad valve guides..... But check valve clearances first !!!
PostPosted: Fri Sep 22, 2006 8:13 pm
Thanks for replies
I will set to with the feeler gauges ths week-end and let you know what the findings are.
Many thanks
Timbo :thumbup:
907 ie red 1992
851 Strada red 1992
PostPosted: Sat Sep 23, 2006 8:00 pm
We are waiting.... maybe some very intresting Paso problem again... :D
