ducatipaso.org • View topic - at wit's end with my F@#*ing clutch
It is currently Wed Jun 17, 2026 6:51 am
 Post subject: at wit's end with my F@#*ing clutch
PostPosted: Sun Sep 24, 2006 1:18 am
Today, I spent all day literally, trying to get the air out of my clutch line. I have came to the conclusion that there must be some kind of air leak coming in from somewhere. Has anyone had this problem? I don't know what to do I have tried everything I know.
very pissed :mad: :mad: :mad:
PostPosted: Sun Sep 24, 2006 8:24 am
PostPosted: Sun Sep 24, 2006 12:42 pm
 Post subject: get the air out
PostPosted: Mon Sep 25, 2006 3:17 am
PostPosted: Mon Sep 25, 2006 4:18 am
PostPosted: Thu Sep 28, 2006 1:38 am
I am familiar with the methods mentioned above but I have taken things a step farther. I took my clutch cover off, put two clear lines: one on the inlet goint to a can of brake fluid and one bleed hole. I ran the bleed hole tube through my vacuum pump. Still sucking gobs of air out. I even siliconed the piston area to see if it was leaking there. This is really blowing my mind. I can't seem to get the air out.
Is there anyone out there that has had bad experience getting air out of the clutch line / cover? Is this an impossible feat?
PostPosted: Thu Sep 28, 2006 2:47 am
Do you have the bleeder screw too loose so that it is sucking air in through the threads? Just a thought.
PostPosted: Mon Oct 23, 2006 1:01 am
PostPosted: Mon Oct 23, 2006 1:44 am
PostPosted: Mon Oct 23, 2006 2:52 am
PostPosted: Mon Oct 23, 2006 4:17 am
-Craig
