It is currently Thu Jun 18, 2026 1:34 pm
[ 14 posts ] |
| Author |
pikey
Post subject: clutch airleak? Posted: Thu Sep 21, 2006 12:21 am |
well, about a week ago I noticed that the clutch was begining to drag a little bit, but by the time I reached my destination, I had no clutch at all. so I took the cover off and checked the plates/piston/bearing, and all seemed well. so I decided to try and bleed the clutch and sure enough there was a good bit of air in the line. after that the clutch worked fine for about a day. and then it began dragging again. same problem. all the crush washers are there and everything seems in order. now the question is how do I isolate such a slight leak? should I just say the heck with it and rebuild from master to slave? any help would be most appreciated!
............pikey
| Top |
nilaus
Post subject: Hi! Posted: Thu Sep 21, 2006 7:15 am |
Joined: Tue Sep 14, 2004 12:00 am Posts: 152 Location: Denmark
Is there any external leakage or is it all internal?
Regards
Klaus
PASO 750, 1990
| Top |
Rodney
Post subject: Posted: Thu Sep 21, 2006 8:11 am |
Joined: Mon Mar 21, 2005 12:00 am Posts: 101 Location: Sydney Australia
:confused: does the fluid disappear as well or does it just suck in air it sounds like the o-ring in the clutch slave bearing is shot you may have to replace this or the whole bearing itself .
Rodney
_________________ Ducati ST2 2002 , Ducati 696 2010 , Ducati Pantah 1983 (in progress )
| Top |
pikey
Post subject: Posted: Thu Sep 21, 2006 9:31 pm |
| Top |
Rodney
Post subject: Posted: Sat Sep 23, 2006 12:10 pm |
| Top |
yellerduck
Post subject: Posted: Sun Sep 24, 2006 1:22 am |
| Top |
Rodney
Post subject: Posted: Sun Sep 24, 2006 1:06 pm |
| Top |
pikey
Post subject: Posted: Mon Sep 25, 2006 9:03 pm |
| Top |
ducinthebay
Post subject: Air in the system Posted: Tue Sep 26, 2006 5:14 am |
| paso grand pooh-bah |
| Top |
BellaPaso
Post subject: Posted: Tue Sep 26, 2006 1:57 pm |
| Top |
pikey
Post subject: Posted: Wed Sep 27, 2006 9:29 pm |
Bellapaso, if I find a resolution I will most certainly let you know!
pikey
| Top |
yellerduck
Post subject: Posted: Thu Sep 28, 2006 1:42 am |
Pikey, I feel your pain. This past weekend, I have spent countless hours trying to get the air out of my clutch line without success.
Now I have taken the gloves off and it's me and the clutch. I took my clutch cover off, put two clear lines: one on the inlet goint to a can of brake fluid and one bleed hole. I ran the bleed hole tube through my vacuum pump. Still sucking gobs of air out. I even siliconed the piston area to see if it was leaking there. This is really blowing my mind. I can't seem to get the air out. So far, it's kicking my butt but the fight isn't over.
Is there anyone else out there that has conquered this problem?
| Top |
pikey
Post subject: Posted: Thu Sep 28, 2006 3:17 am |
I have no problems bleeding the clutch, but then again I have never started with the line empty. I'm never really getting much air. the problem seems solved after I bleed the line, but within 20 miles it begins dragging again. I'm getting murderously frustrated with it. I am about to just friggin rebuild the whole damn thing, from top to bottom!
pikey
| Top |
[ 14 posts ] |
Users browsing this forum: No registered users and 43 guests |
