ducatipaso.org • View topic - What is that noise in top gear???
It is currently Sun Nov 01, 2026 10:40 am
 Post subject: What is that noise in top gear???
PostPosted: Tue Oct 03, 2006 4:55 am
Redpaso
PostPosted: Tue Oct 03, 2006 5:44 pm
PostPosted: Tue Oct 03, 2006 8:40 pm
PostPosted: Wed Oct 04, 2006 5:01 am
Redpaso
PostPosted: Wed Oct 04, 2006 5:21 pm
PostPosted: Thu Oct 05, 2006 5:24 am
PostPosted: Thu Oct 05, 2006 9:27 pm
Redpaso
PostPosted: Wed Oct 11, 2006 5:07 pm
Noising from the 6th gear only is almost certainly a worn pair of gears. Suprising that it is 6th gear, you would expect 2nd or 3rd. Just wear ear defenders and ride normally, when it goes "clonk" and locks up the rear wheel you will be able to identify the fault all the more easily. Has the noise got a vibration? Has it become worse during the past few weeks? Splitting the crankcase should reveal ground metal surfaces or worn gears.
PostPosted: Tue Oct 24, 2006 11:48 am
PostPosted: Wed Oct 25, 2006 6:15 pm
PostPosted: Tue Oct 31, 2006 11:45 am
Redpaso
 Post subject: Re: What is that noise in top gear???
PostPosted: Sun Jan 20, 2008 12:22 pm
have you solved the mystery noise yet?
sounds to me like a chipped gear.
only the outer metal is hardened, and they are soft on the inside, so when they go, they disintergrate quite rapidly. I hate to be a prophet of doom, but check your enigne oil for metalic particles.
