It is currently Fri Jun 19, 2026 4:20 pm
[ 3 posts ] |
| Author |
pikey
Post subject: STUPID IGNITION PICKUPS! Posted: Tue Oct 10, 2006 5:40 am |
well heres the story: started the paso up the other morning, and had a lot of trouble getting her started. once I got her running, the motor sounded kind of rough, but I was still half asleep and just figured it needed to warm up. As soon as I started rolling I knew something was indeed very wrong. There was NO power at all. I then realized why the motor sounded so strange: She was only running on one cylinder! so I finaly made it to the motorcycle shop I work at. first thing I did was put new plugs in, and checked for spark. sure enough the lower cylinders coil was not sparking. so I swapped plug wires and checked spark, and it appeared that the same coil was stil not firing. so then I swapped the lead wires to the coils and the suspected coil fired. Long story short, I eliminated the possibility that the coils or igniters could be bad, which left the ignition pickup for said cylinder. I test both and the lower cylinders pickup was no good. so its either the wire leading to the pickup or the pickup itself. any suggestions? any body know where I can find a set of pickups? all help is appreciated!!!
-pikey
| Top |
Desmo_Demon
Post subject: Re: STUPID IGNITION PICKUPS! Posted: Tue Oct 10, 2006 1:36 pm |
| paso grand pooh-bah |
Joined: Fri Jul 21, 2006 12:00 am Posts: 869 Location: Easley, SC
_________________ 2002 Ducati 748 monoposto 1998 Ducati ST2 1996 Suzuki GSXR-1100 1994 Bimota DB2 1988 MegaPaso 916 project 1987 Ducati Paso 750 1985 Harley FXEF 2001 Ducati M900ie (wife's) 2000 Yamaha YZF-R1 (wife's) 1998 Ducati ST2 (wife's) 1994 Suzuki GSX-750R (wife's)
| Top |
pikey
Post subject: Posted: Tue Oct 10, 2006 8:14 pm |
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 28 guests |
