ducatipaso.org • View topic - 907IE rear wheel bearings ???
It is currently Thu Apr 30, 2026 6:49 pm
 Post subject: 907IE rear wheel bearings ???
PostPosted: Mon Feb 21, 2005 1:21 pm
Hi ALL 907 owners!
Does anybody know, what shall be SKF number for those bearings???
And what are dimensions???
I havent take my out yet(dont know, when i do it), but want to buy
new ones for waiting that changing....
Finnpaso
PostPosted: Tue Mar 14, 2006 5:08 am
Hey Antti,
I just went through all this on a set of 907 wheels.
The SKF # is 62203-2RS-C3 Notice that there are two 2's in that part number. Not a typo! Special bearing, but still in production. C3 is looser bearings, and helpful to take up some side loading, but not necessary.
17mm id x 40mm od x 16mm wide.
The dealer no longer stocks them, and will try to sell you a kit of parts to fit a more standard 6203 bearing, that is only 12mm wide. The kit of parts includes two 4mm spacers, and a new spacer tube. Total is about $200.
Instead, go to a good bearing supply house and get 16mm wide bearing. About $30 each.
Same wheels and bearing as 91-97 SS and Monster.
Phil
PostPosted: Tue Mar 14, 2006 6:59 pm
PostPosted: Wed Mar 15, 2006 8:53 pm
PostPosted: Thu Mar 16, 2006 10:52 am
I have changed also to front wheel SKF bearings, but cant remember numbers... If Someone desperently needs those numbers, surely then i try find that from one of my thousends of notes from garrage liberary :cool:
