ducatipaso.org • View topic - Dual bulb headlight?
It is currently Wed Apr 29, 2026 11:11 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Dual bulb headlight?
PostPosted: Thu Oct 05, 2006 11:54 am
PostPosted: Thu Oct 05, 2006 4:53 pm
PostPosted: Thu Oct 05, 2006 7:18 pm
PostPosted: Thu Oct 05, 2006 7:45 pm
PostPosted: Thu Oct 05, 2006 10:01 pm
THE US spec Yamaha FZ-750 (1987) used the same headlight casing but with dual headlights inside. Apparently they slot in no mods needed. This is something I plan doing after some brake upgrades. These were still available new from Yamaha approximately 12 months ago.
Here is a picture of Pope's Dual Headlight Paso.
Redpaso
PostPosted: Fri Oct 06, 2006 12:12 am
Thanks everyone I will try and find one.
What is the deal with the mesh below the headlight?
PostPosted: Fri Oct 06, 2006 2:17 am
You should have the mesh on yours.
I stand corrected!
PostPosted: Fri Oct 06, 2006 11:59 am
907 Pasos are mesh free.
Regards, B
PostPosted: Fri Oct 06, 2006 1:55 pm
Are the Yamaha FZ 750 EU headlight different from the US spec? No matter, it would have work better than the OEM unit, I guess.
PostPosted: Fri Oct 06, 2006 7:54 pm
I agree You Jon, 907IE is MESHfree Ducati !!! :funny:
PostPosted: Sun Oct 08, 2006 9:43 pm
1992 907ie #1473 Nero SOLD
PostPosted: Mon Oct 09, 2006 7:15 pm
There is ONE bigger problem with Dual H4 headlights: If You use both BULBS TOGETHER, then not enough current from charging system to battery!!!! I have seen this in my 907IE and after 65 kms drive, i have to ask one honda driver to push me with jump start, when i stopped to fuel my bike, so BOTH bulbs cant use same time. 2 X high beam, or 2 X low beam takes TOO MUCH to 907. I KNOW THAT.... Anyway "look" is much better now.... Btw, i put switch to handlebar to dissconnect another bulb and i use ONLY both bulbs , when REALLY NEED and short time then! :evil: That P7 ECU NEEDS enough voltage to function, like should. There is voltage "looking" wire and if voltage drops too low from battery, then ECU cuts off! I know, i know..... :evil: :evil: :evil:
 Post subject: Dual Headlamp conversion
PostPosted: Mon Oct 09, 2006 8:00 pm
This headlamp assembly is listed as P/N 1LJ-84303-A0-00 on this site and sells for $132.17 plus shipping, best price I've found new.
http://shop.yamaha-motorcycleparts.com/ ... /home.aspx
The models it fits are Yamaha 86 FZ750S, 87 FZ700T & TC, and 88 FZ750U, the R models are different. It comes from Japan and is currently back-ordered.
 Post subject: Dual Headlight
PostPosted: Thu Oct 12, 2006 12:27 am
I just finished testing the power output of my alternator. I used a clamp-on current meter on the alternator wire just ahead of the 30 amp fuse. To test for potential output of the alternator, I ran the headlight without starting for about 10 minutes, then started the bike. Altenator output was 20.4 amps at 14.3 volts, or 292 watts. I imagine with a dead battery it might approach 350 watts as speced. I then let the battery charge up and ran it with the high beam at 3K rpm. It drew 186 watts. I believe there is 100-150 watts to spare on these bikes. The previous owner of my bike ran a heated vest and grips, which add up to 90 watts if constantly on. The wiring to the regulator and alternator have been beefed up and an aftermarket regulator put in, so proceed with caution when adding load, lest you'll be pushing it home :sad:
 Post subject: Dual Headlight power
PostPosted: Tue Oct 17, 2006 3:50 pm
The stock bulb for the dual headlights is listed as a 35/35 watt. Is anyone using it with the stock wattage?
