It is currently Tue Jun 16, 2026 12:20 pm
| Author |
nomoduc
Post subject: Should i get this LTD? Posted: Thu Oct 19, 2006 11:53 pm |
Joined: Thu Oct 19, 2006 12:00 am Posts: 14 Location: NorCal Bay Area
| Top |
Finnpaso
Post subject: Posted: Fri Oct 20, 2006 6:32 pm |
| paso grand pooh-bah |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
persempre907
Post subject: Posted: Fri Oct 20, 2006 8:21 pm |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
The price is good for a low mileage, LTD Paso :lick: :lick: :lick: :lick: :lick:
I would buy it... :thumbup: :thumbup: :thumbup: :thumbup:
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
| Top |
persempre907
Post subject: Posted: Fri Oct 20, 2006 8:22 pm |
Sorry....
Which colour, blue or white?
| Top |
Finnpaso
Post subject: Posted: Sat Oct 21, 2006 9:05 am |
Limited (LTD)version was made ONLY pearl WHITE. All others are repainted... :thumbup: Btw, they say, that just that colour in impossible to repaint with same colour. It was difficult colour, if need to repaint some part of bike....
| Top |
persempre907
Post subject: Posted: Sat Oct 21, 2006 5:48 pm |
| Top |
Finnpaso
Post subject: Posted: Sat Oct 21, 2006 7:24 pm |
| Top |
Garnet
Post subject: Posted: Sun Oct 22, 2006 12:40 am |
I used to sell auto paint and found it so hard to match most motorcycle paint that our shop would repaint the whole bike. Real pearl colors are impossible to match becauce the pearl is mixed in the clear that is sprayed over the white (blue red black) base color. To get the match correct the exact amount of pearl must be applied in the same number of coats at the same air pressure, fan pattern, viscousity, temp etc. You could get the tint of the color correct from one angle but it would look wrong from a differnt angle.
Modern pearl colors seen on new cars (mid 90s on) have the pearl look in the base color, where you can play with the look of the color by adjusting air presure and viscousity, much like spraying metalic colors. Modern paints do not change color as you look at them from different angles the same way that a "real" pearl job does, that is how you tell the difference.
Sorry I ran away with the thread.
Is a Ltd Edition worth any more than an equal 750?
Garnet
| Top |
nomoduc
Post subject: Posted: Sun Oct 22, 2006 6:11 am |
Thanks for replies all. I was going to consider all things needed before I made an offer. I was gonna do the belts and valves myself. and get new tires of course also. Pretty much do a full presale service on it before I ride. If I buy it.. I just need to read up on the upgrades needed. I've heard of the regulator,carb swap,some starters need replace...What else is common. I guess I better go through the forum and read up. When I had my 916, I went through a regulator, took off rear spindle to check for cracks,coolant overflow tank replaced... Typical...haha.
| Top |
Finnpaso
Post subject: Posted: Sun Oct 22, 2006 8:29 am |
Garnet, very intresting info from You! :thumbup:
LTD have those bigger headers(like many Euro modells also have), some say, that lightened flywheel(i am not sure about that, cause i havent seen such flywheel). Also maybe more open exhaust pipes and that pearl white colour. So, not so much over normal 750Paso. There is some old topic about this LTD/normal version comparing.... :thumbup:
| Top |
persempre907
Post subject: Posted: Sun Oct 22, 2006 9:25 am |
| Top |
nomoduc
Post subject: Posted: Mon Oct 23, 2006 5:37 pm |
| Top |
Finnpaso
Post subject: Posted: Mon Oct 23, 2006 6:26 pm |
| Top |
persempre907
Post subject: Posted: Mon Oct 23, 2006 8:36 pm |
| Top |
Users browsing this forum: No registered users and 30 guests |
