ducatipaso.org • View topic - Tires, rear brake problem, rear tail light
It is currently Sun Sep 28, 2025 6:45 pm
 Post subject: Tires, rear brake problem, rear tail light
PostPosted: Fri Oct 27, 2006 2:46 am
PostPosted: Fri Oct 27, 2006 4:15 am
-Craig
PostPosted: Fri Oct 27, 2006 9:58 am
PostPosted: Fri Oct 27, 2006 11:39 am
-Craig
PostPosted: Fri Oct 27, 2006 12:05 pm
PostPosted: Fri Oct 27, 2006 7:35 pm
Thanks guys, I knew this site was gonna have some good advice I may go wider with the rear but the front I will leave stock. Any thoughts on the rear brake sticking?
PostPosted: Fri Oct 27, 2006 8:28 pm
There is ONLY VERY SMALL difference between 170 and 180 rear tires, mostly its only "look of bike". I used earlier 170 and last 4 tires have been 180. Not so "big thing" and surely U can use 180/55 without any problems. Front U should use normal 120 tire. :thumbup:
Check that master cylinder in rear brake, that it function, like should. There can be also problem in piston/sylinder: shit inside!
PostPosted: Sat Oct 28, 2006 7:17 am
PostPosted: Sat Oct 28, 2006 7:30 am
