It is currently Sun Mar 01, 2026 7:17 pm
| Author |
Finnpaso
Post subject: Posted: Sun Oct 29, 2006 3:47 pm |
| paso grand pooh-bah |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
persempre907
Post subject: Posted: Sun Oct 29, 2006 5:16 pm |
Joined: Tue Dec 06, 2005 12:00 am Posts: 3312 Location: Roma, Italia
_________________ Francesco Ducati 907IE 1992 Rosso Ducati 907IE 1993 Nero Moto Guzzi Galletto 1960 Sabbia BMW R Nine t 2019
| Top |
Finnpaso
Post subject: Posted: Sun Oct 29, 2006 7:25 pm |
| Top |
persempre907
Post subject: Posted: Sun Oct 29, 2006 11:02 pm |
| Top |
Harigeharry
Post subject: Posted: Mon Oct 30, 2006 10:50 pm |
Joined: Tue Apr 04, 2006 12:00 am Posts: 87 Location: Amsterdam
Maybee this helps, from and older topic:
Before fitting the 150's Reyer fitted the 140 with 750 Monster settings (found on the internet). With CO measurement equipement making the best setting.
Them Reyer took the Paso to a dynorun
With tis as a result:
Reyer thinks the engine still run to lean. So he will put back the 150 jets and tries to solve this. 65 HP on the backwheel must bee possible.
| Top |
Finnpaso
Post subject: Posted: Tue Oct 31, 2006 4:29 pm |
| Top |
Duc750
Post subject: Posted: Tue Oct 31, 2006 6:02 pm |
Joined: Mon Apr 03, 2006 12:00 am Posts: 373 Location: Northampton UK
| Top |
jcslocum
Post subject: Posted: Tue Oct 31, 2006 8:52 pm |
If they show MPH/KPH it usually means that they didn't have a place to hook up the sensor for RPM or they just didn't do it. In my area you can get an el-cheapo dyno run like this for 10 bucks. Very little set up but not much useful information.
They use 4th gear so that the engine has a nice long pull for the dyno to measure.
| Top |
DesmoDog
Post subject: Posted: Tue Oct 31, 2006 9:05 pm |
Joined: Sun Feb 27, 2005 12:00 am Posts: 244 Location: Dexter, MI USA
That's an inertia dyno so I'll take a couple guesses at some of the questions asked:
Plotting the output vs mph saves them from instrumenting the bike or having to get any data from it, such as gearing or tire diameter. Note that knowing the final drive ratio isn't enough to know what the corresponding rpm would be. Take that, measure the tire diameter, and you've still missed the tranny's gear ratios and the primary drive ratio.
MPH can be taken from the speed of the roller - that way all instrumentation is on the dyno itself so there is no added set up time or complications getting a tach to work (accurately) on different vehicles.
They might run it in fourth gear to keep the rear wheel from spinning under power. In any case running it in fourth gear makes it a little less violent of a test. In 4th they aren't going to spin the roller to 200mph nor are they going to go from idle to redline in half a second.
EDIT: Yeah, what he said. I guess I type too slow! :laugh:
_________________ -Craig
| Top |
jcslocum
Post subject: Posted: Tue Oct 31, 2006 10:08 pm |
Your answer must be better, you used 2 times as many words!!
Great minds must think alike!
| Top |
Harigeharry
Post subject: Posted: Wed Nov 01, 2006 11:28 am |
| Top |
Users browsing this forum: No registered users and 1 guest |
